Hey all;
I am doing a frame up restoration on a 1981 Bronco with a 302 Fuel Injected Engine. When I had the machining work done on the engine block I told the shop that I wanted a performance cam and planned to put a 4BBL in it. I am now at the point where I am starting to put the engine back together and am having second thoughts about going with the carburetor. Has anyone done this before and does it make sense? My biggest concern is the what I am going to need to do to the EEC in order to make it work along with everything else it does. I understand that I need an adapter for the AOD TV cable but that seems pretty simple. Am I being an idiot in attempting this or should I go back to fuel injection? Thanks in advance for all your opinions.
