Broncosaurus!
both my chilton and haynes manual conveniently leave out all mention of the fuel gauge and sending unit. How do I test the sending unit and do I have to drop the tank to change it?
If you want to start by gaining access to the sender unit without dropping the tank, you will have ot make an access hole. You can do that with the tank in place, done with fear and trembling, but doable http://broncozone.com/forums/index.php?showtopic=12329 or drop the tank. If you are flexible enough, you may be able to reach up from underneath the truck and remove the connector for testing. The problem could be a bad connection, sender, wiring or gauge, but rarely the gauge. I had to run a new ground from my ground distribution bus to the sender connector in order to get reliable readings on the gauge.both my chilton and haynes manual conveniently leave out all mention of the fuel gauge and sending unit. How do I test the sending unit and do I have to drop the tank to change it?
