I wanted to see what others have used to run your fuel line from the mechanical pump up to the filter then to carb. I have replaced the pump before and was never happy with the previous owners setup. Since I need to replace it again I figured I would take the chance to fix this.
The current setup has an old steel line that screws into the pump, it looks like at one time it ran the full length to carb, but basically has been cut after about 8" and has a fuel line attached. This then runs to my filter and to the carb. I would like to run the steel mesh line this entire length, but my hangup is how to attach it to the pump where it needs to be screwed in. I have found a few 90 degree fittings, however I am unsure if I would be able to use since they do not have the same free moving thread. And I think if I tried to ***** on the fitting the line that comes out on the 90 degree bend would hit the line going into the pump.
Hopefully this all makes sense, if anyone has images of their setup from the pump or products they have used I would appreciate it.
