I have an 87 BII. It quit running after replacing the fuel pump after it got to warm. ran code check and to 34 EGR Sensor and replaced it. Then......no fuel pressure. New fuel presssure regulator, relay and pump. Pump runs when key is turned on. Fuel to rail pump from rear pump but nothing to the injector rail and no pressure at the pressure check valve. disconnected and redid inertia switch. And I can hear the normal click when the pumps run when the key is turned on.
Also doing a static pressure test, when I grounded the fuel pump from fuel pump test connector on the self-test connector, the pump didn't run but I got clicking, and the ABS light is now staying on. Can the ABS sensor cause the fuel pump problem?????
Totally stumped? Thanks in advance for any help or suggestions.
