BlueThunder
- Joined
- May 24, 2007
- Messages
- 71
- Reaction score
- 0
Ok well my front end suspension or something is messed up...
If I'm driving and a hit a bump my front end starts hoping all around...
I've looked out the window while it was happening and it looked like the tires were wobbling on the axles. So i replaced the bearings...it still happened so i replaced the ball joints...and it got better but it still happens...I don't know what else it could be...
I don't know if this could be the problem but i know that my trac bar bushings are shot and the bar itself is bent and all screwed up...apparently the person who put the lift on it didn't want to buy an adjustable trac bar so he cut it..bent it...and welded a piece into it...i mean the bar itself is strong but the bushings are shot and they are leaving a lot of play...Should i replace the whole bar or just the bushings? Could that be my problem?
Could it be the tires? 38" TSL Super Swampers
I know mt tie rod is good...but my drag link is bent...probably from a rock or something from the previous owner...But that should only effect my steering wheel position right?
ANY input is appreciated...and the faster the better...this is a daily driver....
Thanks
Mike
Thanks
Mike
