BOB MARLIN
1990 5.0 manual transfer case and manual hubs.
Transfer will shift into 4x4 high and low with no problem. Light on the dash verifies it, but the front drive shaft is not driven. The low gear works as well as the high gear but only to the rear wheels, no connection the the front drive shaft. I put it up on the lift and can lock and unlock the front hubs and watch the front drive shaft move when I spin the front tire by hand when locked so that part seems good. The transfer case makes no noise or any other symptoms that would make you think something is wrong. It just doesn't engage the front drive. HELP !
