Front brake rotor help!!!!!
LTO-B
Hello, I have a 79' Bronco and need to replace the front brake calipers. My problem is I can't get the allen head bolts on the retainer cap loose. Any body know of a trick to get them out before I end up stripping the heads. I have sprayed them down several times with break free. Any help would be greatly appreciated.
Thanks, LTO-B([email protected]) :rolleyes:
kmeyers
Plymouth, MI
I had to drill the head off of one of mine. Just get the drill bit to fit directly in the retainer hole. Once the head was off I was able to unscrew the bolt portion of it by hand. I guess the metal just oxidized around the head.
Cmprice
try tightening it sme first then try and back it off
89Bronco58
Jersey
soak it down with some PB Blaster penetraiting oil really well, another trick is to tap on the head with a hammer to try and break some of the rust or whatever loose, just dont go crazy when hitting it, just a few swift taps
drubbz
