duckdogwhiskey
duckdogwhiskey
Hey guys. So here is the deal. After my truck went back to my mechanic this weekend, he has said he thought the tapping leak was coming from the egr valve on the truck rather than at the exhaust manifold because after he put in new manifold gaskets, the sound remained. You only hear it when accelerating. He put a weld around where he thought the leak was coming from on the egr tube, but still the sound. He cranked it up for me and put his hand over the exhaust pipe and back pressure immediately started hissing from my manifold. He now thinks that either the manifold has a crack or cracks that he could not see, or it is possibly warped from heating and cooling so many times with a sheared bolt. If this is the case, a new manifold costs about $99 and I could get hedders for about $199 and be done with it, which is what he is recommending. A buddy has some hedders that would not work on his 96 that were given to him, which he is offering to give to me. He has a 302 and I have a 351- 5.8, so I am hoping that since they don't fit his, they may fit mine. Does his assertion about a warped manifold make sense? I would have thought that the gasket set would have sealed it. He said he put quite a bit of torque on the manifold bolts, and someone else has suggested he may have either put too much or didn't follow the tightening pattern, which could cause it to continue leaking. Just don't want to keep shooting in the dark and wasting money. Your thoughts?
