engine swap
forddude007
i want a lil more pull what is the best option stay with a small block or go big. and if i go big what do i have to change out or cut out. i just bought a 1975 bronco and love it. please help n e info is great............ [-X
76Explorer
The Heart Of Dixie
The 351 is a pretty simple swap, with the other two, you will have to modify your frame to allow for the starter, and will probably have to beat the crap out of your firewall to just fit it in. I'm not sure if your radiator will have the cooling capacity for any of them, will probably have to upgrade to a 4 core.
F
forddude007
30143[/snapback]
hey thanks you sound like you know your stuff, 351 it is, it should bolt right on to the tranny right, if not i need an adapter right........if you don't mind whats your email address i got lots more q's for ya.......thanks again.....
bajaplayboy
30120[/snapback]
Well I know alot of people hate this motor but its easy to find and a torque monster (about 425ftlb) its the ford 400...but you have to build it abit. I the great thing about it is that the 1981 F-250 400 motor mounts fit right in a the bronco frame, plus then you get a big block C-6 and a NP 205. Just an idea...works for me anyway. the only issue is headers fitting....but a welder and a torch adn its all better.
79' Buckin Bronco
