BroncoNutt
- Joined
- Dec 17, 2006
- Messages
- 70
- Reaction score
- 0
Man this sux!!!
It snowing again and I want to drive it!
/emoticons/sad@2x.png 2x" width="20" height="20" />
Does anybody know what the 0 degerease mark looks like on the bronco?
Im confused because it has a big mark on the the pulley that is a factory groove in the pulley. Then, their is also 2 other marks on the pulley that someone painted on? When I found the cylinder 1 compression stroke it was on one of the marks that someone painted on the pulley?
Im confused!!
Can someone explain?
Ya I see it..take a look @ Ryan's pic and info here; see the groove on left side of da pulley?http://fordfuelinjection.com/index.php?p=71
the SPOUT needs to be pulled to time it; it should be in to start.Ya I see it.. Im thinkin mine turned or something or its old and doesnt show tdc on the groove anymore.
Will the truck not start if I dont remove the plug on the dist to start it initialy?
do you have the e4od transmission? if so torque converter lockup is controlled by the computer. there should be a large electrical connector on the passenger side of the tranny. unbolt and unplug. do not drive the truck like this just put it in reverse and see if it stalls. if it doesnt the problem is with the electrical unit in the tranny.Thats Exactly what happens to mine... I wonder what that could be?
Engine light or Check engine light?What size engine?My Bronco Is having Problems... Its been sitting for a year before I Got it. It runs great... KINDA!
for some reason the Idle starts to surge when the engine light comes on , I have to rev it up high and it clears for a little. Its fine in park or Neutral, When I put it in Reverse or Drive it starts to die and I have to give it gas to keep it running. Sometimes it just dies?
Im thinking It needs a new Fuel filter, Its been sitting for a while so It may be water in the tank that got the filter all cruddy.
Also the engine Doesnt have great throttle response at all! I floor it from a stop and it just takes off slow and then starts to kick in. I know thats not how the motor is supposed to run!
The engine had a tune up Before it was parked a year ago....
Someone else had this problem also.. They also had to start their truck by Jumping the Solinoid with a ***** driver. THats what Ive been doing also, I dont know if that has any thing to do with the way it runs like that but I would like to know what that problem is also... Someone said it may be the Neutral safety switch? Im gonna get one and put it on just to try.
Any help would be helpful! I need this truck for a daily driver... If I dont have this truck I dont have anything!
Thanks Much.
Thomas
Probably not neutral safety.More than likely your right about the fuel filter,and also sounds like the air filter. I would assume that your idle speed sensor,and/or your throttle position sensor is either fried or close to it.Also check the O2 sensor.Engine light or Check engine light?What size engine?
Ya i Checked it and It seems correct by what the Chiltons manual says.. Also ive yet to move it a tooth over... The truck seems to shake alot..Are you positive the firing order was done correctly?
I have the C6lucky it didnt run you over. do you have the e4od transmission?
