I have a 78 Bronco with a 400 engine and aHolly 750 carb, which I plan on replacing with a Edelbrock 650.
Anyways, when I’m in second gear and increasing the RPM to switch into third it’s like the engine starts to die. I can drive okay as long as I don’t accelerate too fast. While at idle if I step on the gas to increase the RPM to over 2000 it acts as if it’s going to die.
I replaced the filter, fuel pump, adjusted the accelerator pump and verified the timing.
Any ideas on where else to troubleshoot?
