Engine misfire?
michealtheworm
i have i 93 5.8 bronco. it runs great but sometimes when it heats up it misfiring 1 cylinder. plugs, wires, distibutor cap and rotater is new. got any ideas?
AdamDude04
Going through any coolant? Could be a slight leak in that area causing a missfire...
Hard to really say. Maybe another bad plug LOL
89purple horse
colorado
i am no expert by anymeans worm but u might wanna just check the basics make sure the wire hasnt got up against the manifold burning a hole and causing the wire to arc. as adam said could be a bad plug maybe even a bad cap never had one but it could happen.
yo
Good info 89PH!
Michael; did this misfire start after changing the wires.etc.?
Check Spark Plug Wire Routing for 5.8
94-96 5.0 ** - INCLUDES 5.8 - engine miss, spark knock, buck/***** surge and other driveability concerns
Source: by Tank92 (Tank) at SuperMotors.net
Or use that Label on top of radiator (VECI Label)
If gone;
On-Line for Free at Ford. Click "Quick Guides" in left panel; Scroll to & CLICK VECI Labels "Provides Vehicle Emission Control Information (VECI) and a related calibration parts list." Enter applicable info (need to know your Calibration number from your B-pillar sticker). Vacuum Diagram is the same as the one on the core support or hood or air filter cover.
honesthat
