engine help????
kyrikos
hi my name is kyrikos i own a 93 for bronco with 214k miles on it. i bought it from a buddy of mine that didnt use the truck towrds the end it sat for almost a year, ill keep it short i did all the full motosport tune up when i got it fixed rear main seal was leaking and also leaking from oil pan i replace oil pan, oil pump, and seal everything wwas fine till i towed my 23 ft boat out this weekend for about 50 miles came back home let the bronco sit woke up in the mornig i had three puddles oil under the truck 1 rear seal 1 oil pan gasket looks like and another in the front. now i would like to get some openions on this should i rebuild engine or just fing out what caused this fix all seals?/// buy the way last month i changed pcv valve too help please!!!!!!!!!!!!!!!!!!
Welcome to the Zone > . Post a couple of pictures when you get a chance.
As far as the oil leaks, as long as the engine runs OK and the transmission seems good, I'd just find out why it is leaking. To me it sounds like the gaskets a seals were either not installed right or the bolts on the oil pan are not properly torqued.
K
kyrikos
the ford dealer told me the same that if the motor aint smoking burning oil or knocking just replace all the seals... it would be about 900 for the dealer to do it.
i just dont really want to through my money twice beause the motor has 214k miles if i do all the seals and then down the road it blows then i spend 2500 to rebuild it... thanks for the help i will post pics soon..
