entity-unknown
I just went through emissions and failed both my first tests. First time I was at 8.8 on NOx, then put in better gas, added some acetone, and now I'm at 6.5 but that's 1 over.
This typically leads someone to check the EGR so I did. If I attached a hose to the port, I can **** on it and it operates. It doesn't take much to make it move but if I wanted it to open all the way, I better be a professional ******. Point is it works and I replaced it two years ago when I failed my last emissions test. I skated by on that one, which was odd because the 10 tests before (long story lots of money) I passed every time until I fixed the fuel pressure issue. I had a mm size sand grain that was inbetween the fuel pump o-ring and the gas tank which gave enough for it to give out on the presssure....
So, I replaced the entire green plastic line for the EGR valve. I watched the diaphram as I revved it up and it didn't move. I tried this with a cold and hot engine. When I put the end coming off the solenoid in my mouth, I can always feel a bitt of suction action, in a rhythm as if you said put put put put put but it's very light. My understanding is this should never occur at idle, or cold engine, which it is. When the engine got hot and I revved it up i did this again, and it was mildly stronger but not much of a difference and it still didn't operate the EGR. So I pulled the red line from the solenoid, stuck that in my mouth and I felt like I was at the dentist with that sucker in my mouth closing my lips and almost havin the air sucked outta my lungs. So I got good, strong vacuum. I also checked all the other lines and they all look good except the one I repaired.
Also if I **** on the attached hose to the EGR when firing up the engine, it goes from idle to crap then back again as I stop sucking so this also tells me my EGR is still good.
When I do an ohm test on the solenoid it's at 42, so that's good but my imagination tells me it's still frozen, causing the EGR to not open, and causing me to fail my emissions test. Anyone able to offer any input? Will this change most likely give me the difference I need to pass?
Crappy part about that solenoid is Checker, & Autozone don't have it. Checker can order it but it's a real special order. Napa was able to order it for me too but either way I have to wait a week and the real bad part is I need my truck next week because my job is 40 miles away... You'd figure this being an emissions part, it'd be more commonly available...
If you have small children and they viewed this, I apologize for all the sucking but it was necessary
/emoticons/[email protected] 2x" width="20" height="20" />
