Did you recalibrate your speedometer after changing the size of your tires. An easy check is to drive 10 mile markers on a highway marking what your odometer says a t start and finish. Then you have an accurate readout in percent. Plus you don't have to maintain any particular speed while doing the check. ex. 10 mile markers and your odometer reads 9.5 mi you are reading 5% low.just food for thought but, my bronco has 3.55 gears and going 75mph i'm turning 2500rpm :blink: prob. because of the overdrive trans. and i'm getting 11-12mpg.(i lost 2mpg by getting the 32" tires rather that the 31's i had before)( next time i need tires i will get the 31's againi just retested the rpm speed again my mistake i'm only at 2000 rpm at 75mph
whoops b-(
27409[/snapback]
