E4OD
bidibronco
Norfolk Va
I have a '94 EB full size Bronco and everytime I let the motor slow me down, it sounds like its grinding in the tranny a little. Not to bad I don't suppose, almost like it doesn't have enough fluid in it but I just changed the fluid and filter. Anyone with any info to give would be nice.
Noises can come from the torque converter, tranny or transfer case. If you don't see any obvious problem on the outside, look for a good transmission repair shop. As costly as it is to repair the E4OD, you may need to get 2 or 3 places to look at it. What does the fluid look like? If you just changed it, did the old fluid look dark brown or smell burnt? Often, a bad u-joint will make you think the trans. is going out. Check those, too.
