yo;
Try this;
Parking Brake Cables ('92-96)
1 Control Assembly 2780
2 2 Nut M8 x 1.25 Hex ****** 17-23 N-m (13-17 Ft-Lb) N620481-S
3 Cable Assembly, Front 2853
4 Cable Assembly, Intermediate 2A793
5 Equalizer 2A602
6 Bracket 2530
7 Rivet N647097-S
8 Clip, 10 x 10 N800962-S32
9 ****** Tap 5/16-18 x 3/4 Hex Washer Head 24-30 N-m (18-22 Ft-Lb) 40949-S2
10 Cable and Conduit Assembly, Right 2A635 (Wagner BC132090 / BC94490)
11 Cable and Conduit Assembly, Left 2A809
12 Clip N804729-S11
13 ***** and Washer 5/16 x 18 x .50 Hex Head 17-23 N-m (13-17 Ft-Lb) 57632-S2
14 Steering Column Support 3B139
Park Brake Cable Removal
1.Remove the left kick panel.
2. Disconnect the parking brake indicator light switch connector at the control assembly.
3. Remove the three nuts holding the control assembly to the steering column support. Pull the control assembly away from the steering column support.
4. Relieve tension on the parking brake system by having an assistant pull on the intermediate cable until all cable is unwound from the control assembly.
5. Insert a 5/32-inch drill bit or equivalent into the hole provided in the control assembly. Try to "reverse install": this; by adjusting assy and then inserting the bit
6. Disconnect the front cable from the cable connector.
7.Disconnect the barrel end of the cable from the control assembly.
8.Disconnect the cable conduit from the control assembly by inserting a 1/2-inch 12-point box end wrench over the conduit snap fitting to compress the retaining fingers and backing out the snap fitting.
Installation
1. Route the cable end fitting over the cable shoe. Snap the conduit fitting into the control assembly housing. Insert the barrel end into the hole in the track.
2. Position the control assembly to the steering column support and install the three retaining nuts. Tighten to 17-23 N-m (13-17 ft-lb).
3. Connect the front cable to the cable connector.
4. Connect the parking brake indicator light switch connector.
5. Carefully remove the drill bit from the control assembly. NOTE: The control assembly will tension itself when the drill bit is removed.
6. Operate the parking brake
