Dura Spark
RoadWarriorRepair
does a 1983 ford ranger with dura spark ignition have a resistor between the ignition key and the ignition module . if so is it a resistor or a resistance wire. i have no voltage reading in the red wire on the module and no spark to the plugs . can i use a test lead and put 12 volts to the red wire without harming the module to see if i can get spark to the plugs. my ford ranger repair manual haynes 36070 shows a resistor in the circuit but trouble shooting procedures indicate the module red wire should have a voltage reading equal to the battery voltage reading. what fuse in the fuse box woulds protect the circuit from the key to the module
kikenhorse
Motor Man
New Brunswick Canada
B) I looked in the manuals I have and it is not too clear.
If I were you I would alternate the 15 amp fuses and then the 20 amp.
There are not that many. It would not be a 5 or 30 amp. :mellow:
Sufferedformula
