Driveline Vibration
okleven
I have a '73 Bronco that I have installed a 3.5" lift on, rebuilt the C4 transmission, transfercase, rearend, and installed a new driveshaft in the rear. The problem I have is a rythmic vibration that is especially noticable at high speed. It cycles every 2-3 seconds. I also hear a clunk when I hit the gas and also when I let off the gas. My first thought is that it is a driveline angle issue. Any ideas?
admin1
Supreme Commander
Administrator
Here are common things that could cause the vibration...
bad u-joint
loose drive shaft slip yolk
off balance drive shaft
Here are common things that could cause the clunk...
bad u-joint
excess ring & pinion clearance
Hope that helps,
Dana
P.S. It could also be a combination of several of these items?!?
davids78bronco
fabricator extraordinaire
central Oregon
okl, I'd run with your idea of the possible bad driveline angle. Is your driveline a 2-joint, or 3-joint? 2-joint being a standard driveline with a U-joint at each end. If this is what you have, then you need to make sure your rear Tcase yoke, and rear axle yoke are within 2
ted_nicolas
Driveshaft may not be fully balanced or out of balance due to worn U-Joints.
Check for a broken off tab (in yoke, keeps u-joint centered).
If broken off of one side of yoke, it may let the u-joint be installed
slightly off center, causing unbalance. Replace Yoke.
EXTREMELY LOW BUDGET, DRIVESHAFT BALANCING TRICK:
Buy two large radiator hose clamps (new, not full of grease or dirt).
Clamp them onto u-joint close together,
with the hose clamp heads about 120
G
Guest
Guest
U-Joint it is! The joint that went into the transfer case yoke was sheared. I can't believe it stayed together! It had been acting like that for a while. It didn't have many miles on it. Maybe 1-2k. The Bronco hadn't been used for a while, though, so the grease could have gone bad.
Broncoholics
Broncoholics
Washington State
I'd have the driveline ballanced, new u-joints, new splines on the slip yoke and a CV on the T-case end. I added traction bars which helped big time. I never replace u-joints with 38.5" SX's! Make sure the pinion nut is tight and have good gear fluid.
K
KROWBAR26
Guest
Driveline angle is probably cooking the U-joint. I had the same problem when I went to a 3.5" spring lift. New Spicer U cooked in about 500 miles. Put on new rear axle with high angle pinion. Problem seems to be gone.
79' Buckin Bronco
