drive train vibration
ghuds
We recently installed a rough Country 2 1/2" lift and 33" tires on my son's 92 Bronco. Since then it has developed a nasty vibration from start to about 40 mph. - above 40 it goes away. The vibration dosen't change weather in 4x4 or 2x4. It is really evident when letting off or slowly applying the throttle. The U joints seem ok - could it be something in the transfer case? It sounds like it is coming from under the rear of the drivers seat. Help - he is out of money and really frustrated!! :((
89Bronco58
Jersey
hmm well, id start by making sure everything is tight and the u joints are ok, replace them anyway, they arent much, make sure the shafts are all ok and ive heard that when after installing a lift the front end may need to be aligned, try that, i doubt thats it but you never kno, sounds liek a balance or looseness problem to me
RodLee
Temple, TX
Have you had the tires ballanced? When I rotated my 33's I got a lot of vibration in the steering wheel around 50 mph. Then had them ballanced. problem solved.
G
ghuds
32453[/snapback]
The tires were balanced and the front end aligned after the lift was installed. The vibration is definitely coming from somewhere in the drivetrain.
bidibronco
Norfolk Va
I've heard of people putting a lift on there trucks and the driveshaft angle be off a little. I'm not sure if that's it but maybe something to look into.
G
ghuds
32461[/snapback]
Thanks for the info! I was thinking that was a good place to start. The rear driveshaft is really angled now - i'm going to disconnect it and just run the front axle to see if it goes away. Thanks again!
cw95bronc
I have a 95 bronc that is not lifted, good balanced tires new hubs and bearing on front. I have the same problem at 35 to 40 mph regardless of which gear or drive its in accelerating or braking. I am corius to find out your results. Any help would be greatful
cw95bronc
ooops! Sorry made a mistake
