Doors/front clip????
derrick36
I'm wondering if anyone knows the physical differences in the doors between the 87-91 models, and the 92-96 models? I know that I can swap the front clip from a 92-96 on to my '91, but I'm unsure about the doors. Looking through the broncograveyard.com website, I see there are 2 different part #s, but I can't tell the difference. 87-91 and 92-96 look like the same doors.
D
derrick36
Thanx. I'm buying a '96 f150 that has awesome doors and a perfect front clip to swap on to my '91, and I want to see how much I can use. The great part is, I can buy the whole truck cheaper than can buy the front clip peices from Jeff's Bronco Graveyard!
When you change the front clip you also need to change the peice that goes between the hood and the windsheild . The antena and the windsheild squirters mount to it . Other than that the entire thing will swap check the headlight plugs and make sure there the same I am swapping the front clip on my 89 and I know that the headlight harness plugs in different between 87to 91 and 92 to 96 so you may have to do some splicing . :D /emoticons/[email protected] 2x" width="20" height="20" />
D
derrick36
21086[/snapback]
Ya, I'm pretty sure the headlight are different. I managed an auto parts store for a few years, and If I remember correctly the 92-96 bulbs are different than the '91, but that's the least of my problems. Good info on the peice between the hood and windshield. I thought that was the same.
Thanx again!
Wihill
