Yo Shawn,Problems reinstalling fiberglass top with bronco graveyard kit. I can’t get the front two drop in. New weatherstrip that goes on bronco was to tall so had to reinstall old one and it still won’t lineup. Any thoughts?
Thank you. I’ve already started reading some of it. I’ve been fighting a high idle ever since the power wash of the engine bay. When I put the code reader on it I get 10, 11 and 15. The first two look great but then I’m guessing 15 is not establishing communication so 10 and 11 are not accurate?Yo Shawn,
Hope you recover from both soon!
Here is some read material for your whike you recover;
1990 F Series/Bronco Pre-Delivery Shop & Electrical & Vacuum Troubleshooting Manuals (EVTM), Partial by member Kingfish999 in Google Drive (similar to your 91) @ 1990 Ford Truck service manuals - Google Drive
Slow scrolling for my slow Comcast Highest Cost Blast Internet..
Suggest you download the docs for faster scrolling and to use the page index.
1991 Bronco Dealer Brochure by Ford via via Dezo's Garage @
https://www.xr793.com/wp-content/uploads/2020/07/1991-Ford-Bronco.pdf
Haynes Red Manual for 80-95 Bronco & F Series @ Hanes guide 80-96 bko f series.pdf via BroncMom
P.S. I have got it all the smog and extra 10 miles a vacuum lines. I went with a plug-in EGR module. I also found the correct throttle cable for this engine. I did have to heavily modify my gas pedal but now I have full Control of my throttle and I am amazed at the difference it made.Thank you. I’ve already started reading some of it. I’ve been fighting a high idle ever since the power wash of the engine bay. When I put the code reader on it I get 10, 11 and 15. The first two look great but then I’m guessing 15 is not establishing communication so 10 and 11 are not accurate?
Hate to be the wet blanket on yer' party there, but before you spend the weekend and the case of adult beverages removing your doors with attached mirrors, you may want to check your RMV vehicle code for necessity of doors / mirrors r/t FACTORY installed parts. Just sayin'.....And if it's legal to remove, dang, go ahead and do so. Then post it on YouTube, so we can all en
Item | Part Number | Description |
1 | 17724 | Outside Rear View Mirror Gasket (Upper) |
2 | N806345-S47 | *****(s) |
3 | N803763-S36 | Riv-Nuts |
4 | 17724 | Outside Rear View Mirror Gasket (Lower) |
5 | 17682 | Outside Rear View Mirror |
6 | 17723 | Outside Rear View Mirror Head |
A | — | Tighten to 4-12 Nm (35-106 Lb-In) ● |
installed and different from the previously mentioned "permitted vehicles".
96' 5.8 EB
90' 5.0 XLT
Welcome to the club Shawn. I hope you have a speedy recover too.Yo Shawn,
