door locks
Regular Joe
I can hear the module/relay when I push key fob to lock/unlock doors but they dont respond. what is the operation sequence supposed to be? I know the locks are to not operate if the engine is running so I am wondering if a bad door "dome light" switch would stop the module from unlocking the doors?
Any advice? Joe
I should also mention that the unlock buttons on my door panels do not work either even though I can hear the relay under the dash operate
yo Joe,
WELCOME!
96 Bronco-F-Series Workshop Manual by Ford
https://www.motorcraftservice.com/pubs/content/~WSTJ/~MUS~LEN/21/STJLEFT.HTM
Section 01-14A: Handles, Locks, Latches and Mechanisms
Symptom Chart — Power Door Lock Diagnosis
https://www.motorcraftservice.com/pubs/content/~WSTJ/~MUS~LEN/21/STJ1EA05.HTM
  • All Door Locks Inoperative
  • Locks circuit breaker open.
  • Battery/power circuit.
  • Poor ground.
  • Circuitry.
  • Door lock switch.
Do Test B
using Electrical Schematics
https://www.motorcraftservice.com/pubs/content/~WSTJ/~MUS~LEN/21/STJ1EA03.HTM
I'd go through it for you, but I have to take a break.
a bad door "dome light" switch (Ford describes it as a Door Jamb Switch in diagrams) is part of the RKE ckt, but Ford does not provide the circuit inside the RKE Module; but if one is Not completing ckt, the other jamb switch for driver or passenger door, if good, will compl ckt & unlock, doors
Here is the Electr Diagram w/RKE;
https://www.motorcraftservice.com/pubs/content/~WSTJ/~MUS~LEN/21/STJ1EB06.HTM
Pull door panels;
test for batty voltage @ PK/BK  (Pink/Black wire) while using remote or door lock switches
I have a little blurry vision so I'm off a bit again.  Will try later if you can pull the panels and test that wire
for future reference:
Diagnostic Service Tips TSB 97-24-13 for 94-96; miesk5 note; the programming connector location described is incorrect for Bronco; it is the grey connector taped to all the wires. to right of strg column
Source: by Ford via v8sho.com
http://v8sho.com/SHO/Remote%20Keyless%20Entry%20TSB%2097-24-13.htm
1996 Bronco Owners Guide (Manual) by Hiller Ford
http://hillerford.com/resource_library/owner_manuals_pdf/1996_owner_manuals_ford/96bronco.pdf
PAGE 121...
guilhermeknob
