Dies when shifted into gear
Kauffmanbros
Over this weekend I was out on some logging roads (gravel and dirt), no extreme four wheeling. A friend went to move my Bronco that night and set the high idle that I've never used before. For whatever reason it wouldn't come off. After almost a full carb re-build in the woods with minimal tools. We found a piece of plastic that had the secondaries stuck open. This was causing really high revs after start up, but once the plastic was removed it was fine. The next morning I started leaking coolant and found the thermostat stuck closed. Removed the thermostat and got ready to hit the roads with the rest of the group. After a few hours of perfect running it started to flood again. Seems to be coming from the secondaries again. What would happen is the idle around 900rpm wasn't enough to keep the motor running once engaged into gear, it would bog down and die. To limp it home we set idle to 1800 and I would roll into the throttle as the motor would die and it would lug then once up to speed run fine. I don't know if any of these other issues will help with diag, but they all happened within 24 hours after the high idle/plastic issue. I can't think of any other helpful info at this point. Any ideas what would cause the motor to die when shifted into gear?
p.s. I'm going to be changing my flex plate. Anything else I should do while I have the transmission off? Kind of a while you're at it?
1986 XLT 351-Edelbrock 1406 w/elec choke-automatic trans
I'd check the secondary linkage again, maybe sticking.  If not that, I'd go over the entire rebuild and make sure something wasn't set right.
K
Kauffmanbros
Sounds good, but do you know what causes the engine to bog down that far when the trans is engaged?
Engines will bog from either too much gas or too little gas, both caused by carburetor being out of adjustment.  You are putting a load on the engine, you could chalk the wheels and hold one foot on the brake while you give it some extra gas with the other foot.  If that works, I'd suspect the idle mixture adjustment, but I would go over all the recommended adjustment of the carburetor manufacturer of the ones sent with the rebuild kit.
K
Kauffmanbros
Good call, I'd rather just make sure everything is at spec and go from there. Thanks for the answer.
Elmomo
