Dashboard
XLT79
Hey,
a couple questions on lighting within the dashboard etc.
1. Why is my dashboard so dim ? new battery and new alternator. Whats the source of my power ? Bulbs ??
2. The drive indicator light box on the steering column - does not work or it appears, at random, on shifting ? A dead wire/connection within column or ?
I'm really in the dark on this.
thanks
Bronc76
Did you check to make sure that the dimmer **** that controls the brightness on the headlight switch is turned in the correct position?
X
XLT79
Ah, ya. We are on full dimmer.... it is most likely a ground or faulty connection. I suppose I need to take the dash apart to get at it....
Sufferedformula
