Dana 44, 5-Bolt camber shims,
Bob Smell
Beavercreek, Ohio
Does anyone know, where Dana 44, six inch OD, 5-bolt camber shims, for a spindle to steering knuckle can be bought? It, is needed for a 1978 Ford Bronco.
I, bought the wrong item, from East Coast Gear Supply. It, has a smaller bolt circle, and it has six holes.
The attached pictures, show the ECGS shim, inside of the six inch bolt circle, on my Bronco.
I, tried the shims from https://www.ebay.com/itm/133928122053, and they don't work either.
muddrivermike
Texas Arp
Dont know why nobody has replied to this. Why dont you just use the offset camber bushing that screws into the top? Those shims súçk.
Bob Smell
Bob Smell
Beavercreek, Ohio
The offset bushings, alter camber, and caster. With the stock Dana 44, the Ford specifications are 1 to 3 degrees positive camber. I, want 1/2 to 1 degree negative camber, and the bushings alone, will not provide that correction.
Similar threads
T
Replies
Views
2K
Top stories on BroncoZone.com
T
T
Replies
Views
1K
T
T
Replies
Views
2K
T
T
Replies
Views
1K
T
CD66
