winemaker
is there any recalls on this truck that im not awere of
I have an 89, 302 v8 motor (5.0) and my setup is via vacume system.
For example, I have a large soup can looking device that is loctated on a shelf right below the driver side headlight inside the engine bay. This "soup can" is simular to the can on the passanger fender behind the battery inside the engine bay.
What happens is, if that soup can rusts, and a hole is exposed, you have no vaccume - thus no cruse control. I'm unsure what the soup can is for on the passanger side of the engine bay tho..also has two vac hoses going into it as well
Your grammer sucks lol.. but from what I gatherd.. you have a newer bronco..so I'm not of much help.my truck is 1995 eb edt with 5.9 its not comeing on onthe dash also my upper console is not working i checked all the fuses will different size tires make my truck shutter when shifting in and out of overdrive
