yo ROCK,
You have a 1995 full size eddy bauer ford bronco 5.0 WITH A E4OD TRANNY...
correct?
If so
Did you or a previous owner get this RECALL WORK DONE?
Recall for 93-96 Bronco, 94-02 F-150, 97-02 Expedition & 98-02 Lincoln Navigators; NHTSA CAMPAIGN ID Number: 05V388000, 07V336000 & 05V017000; Recall Date JAN 27, 2005 & Update; (search for 07V336000 & 05V017000 in "Safety Recalls)' ON CERTAIN SPORT UTILITY VEHICLES AND PICKUP TRUCKS, THE SPEED CONTROL DEACTIVATION SWITCH MAY OVERHEAT, SMOKE, OR BURN THIS CONDITION
COULD LEAD TO A FIRE. FIRES HAVE OCCURRED WHILE THE VEHICLES WERE PARKED WITH THE IGNITION 'OFF.' AS AN INTERIM REPAIR, OWNERS WILL BE INSTRUCTED TO RETURN THEIR VEHICLES TO THEIR DEALERS TO HAVE THE SPEED CONTROL DEACTIVATION SWITCH DISCONNECTED. AS SOON AS REPLACEMENT PARTS ARE AVAILABLE (EARLY APRIL 2005), OWNERS WILL BE INSTRUCTED TO RETURN TO THE DEALERS FOR INSTALLATION OF A NEW SWITCH FREE OF CHARGE. OWNERS MAY CONTACT FORD AT 1-800-392-3673. (NOTE: ALSO SEE RECALLS 05V388 AND 06V286) FORD RECALL NO. 05S28. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO
HTTP://WWW.SAFERCAR.GOV
Source: by Ford & NHTSA via miesk5
Recall Problem; "...I have a 95 Bronco and back in feb.-11- 2010 my rig's master cylinder's Speed Control Deactivation Switch connection
caught fire, this is what the recall "speed control system" is and the recall is still on going. Just go to www.fordowner.com to find out about recalls. After contacting Fordowner.com and filing a claim they passed it on to the claims group @ FORD to be reviewed. Once the group reviewed my claim then someone got in touch with me, I have to mail copys of my title, bill of sale, ect. and copy's of photos of the damage to her. She said that the dealer dose not have parts for vehicles 10 years and older so I have to get my local shop to replace the master cylinder and the wires that were effected by the break fluid and their labor cast, she will cut me/the shop a check and then after the work is done then the dealer will look it over to make sure the truck and the work is up-to-date. All this to fix something that at most costs $200. ***..."
Source: by Belafox
took it to the dealer today and got a new one installed free ." 12 April 2011
Source: by tr21triton
Speed Control Deactivation Switch Location pic in a 95
Source: by Trucky18 (Bco)
http://www.supermotors.net/clubs/superford/registry/3749/28297
Air Bag - WARNING; Read all Safety Info; Such as, remove a battery terminal (Remove both) then wait 30 minutes before attempting any work on the airbag circuits; I have found a few vehicles that had an aftermarket component in it that had a 12v DC or higher re-chargeable battery
Wiring Diagram in a 94
Source: by Ford
http://ww2.justanswer.com/uploads/jmcdo28/2010-03-07_150406_scwiring.pdf========
and for BOTH CRUISE AND HORN problems:
Clock Spring Exploded pic; "...'94-up with driver's airbag) showing the film circuit which abrades & breaks over time, causing SRS warnings &/or inoperative cruise control"
Clock Spring Part Number; "...The replacement clockspring DORMAN 525-200 does not list build year 1995. I could'nt find a clockspring for 1995 anywahere, so I ordered the 525-200 anyway. The OEM clockspring on my 1995 Bronco XL w/o cruise looked different than its replacement. It was attached with2 plastic tabs, not the 3 torx screws described above. I was able to replace it with the 525-200 by using 3 self tapping screws, where the tors screws should have been..."
Source: by irobbrecht
Clock Spring Removal Video in a 94
Source: by pfun41
or Scroll through his vids; also see pther vids he did for Bronco repairs!
HORN checks
96 Horn Wiring; sim to 95
Clockspring Wiring Connector
Pin Number Circuit Circuit Function
1 � Not Used
2 848 (DG/O) Speed Control Switch to Amplifier
3 � Not Used
4 � Not Used
5 151 (LB/BK) Speed Control On-Off Switch to Amplifier
6 1 (DB) Horn Switch Control
7 � Not Used
8 � Not Used
9 � Not Used
10 158 (BK/PK) Key Warning Switch to Buzzer
B3 CHECK CIRCUIT 6 (Y/LG) FOR SHORT TO GROUND
Check for ground short in Circuit 6 (Y/LG) between horns and horn relay.
Check for ground short between high and low pitch horns.
