coolant gauge inop.
89broncobuc
can someone give me a run down on how to diagnose this? I would hate to be driving around and blow the radiator.
89broncobuc
josteve said:
The gauge won't protect the radiator; the cap does that.
Pull the R/Wh wire straight off the sender & ground it to the block, intake, or head. Then turn the key to RUN. If the needle pegs, replace the sender. If not, diagnose the circuit. Also, read this caption:
If you put some specs in a signature, I could give you more info: year, trim level, engine, trans, miles, & mods are good to include. An avatar of the truck is also useful.
Thank you so much, between you and a friend of mine i got the info i needed thanks again
dfos351
What about the same problem on a 90 with a 5.8? And it has a new temp sensor.
chuckles1856
Got a question on this temp sensor....does it feed into the ECM to be used there or is it just used by the temp gauge in the console?
mindy
