90bronco86
Is there a cold air intake made for a 1990 broncos 351? And if not will it hurt anything if I make my own?
I never said that you asked a dumb question. I was telling you the truth about a KN filter and my opinion about dumping a lot of money into something that really won't buy you a thing. KN spends a lot of money hyping their product. The thing is that there is no need for one if you don't increase the displacement of the engine.Im just trying to.get the best performance out of my truck that I can, and ive always.been told cold air intakes give more power andgas milleage. But I'm.really just starting as a diy mechanic. So Im sorry if I ask a lot of dumb questions.
thank you all for the help I really.appreciate it
I didn't mean it like you were implying that, I was just saying I felt they were kind of easy and well dumb lol, but I really appreciate all of the help you guys give.I never said that you asked a dumb question. I was telling you the truth about a KN filter and my opinion about dumping a lot of money into something that really won't buy you a thing. KN spends a lot of money hyping their product. The thing is that there is no need for one if you don't increase the displacement of the engine.
If someone can show me a dynomometer test that shows any improvement in a stock engine with a KN verses a stock engine with a stock filter, I will eat my words. I agree that they may aid a modified engine. (test data supplied by an independent testing group that is)
Sunny California totally fer sure dude but also because mine is different on my '96 Fred. The top is still mounted to the upper radiator support but the bottom was mounted (stock) to the side of the support next to the radiator. They both pulled in fresh air but the bottom one sat really low so I removed it. I have mass air with a air temp sensor in the side of the air-box and the small coolant hose off the radiator fill neck that goes to the throttle body to help with cold weather starting and so the throttle plates don't freeze open but I've also heard it's because coolant is cooler than the fuel vapor that is going in the canister purge port on the opposite side of the throttle body (IAC side) from the canister purge solenoid. It gets plenty of air anyways the way it is and with the larger K&N inlet it pulls it in fast, probably 5-6 inch plastic tube with dual ends for the throttle body. The mass air was adjusting for the increase so I put an oil soaked piece of red pre-filter, that goes around the K&N cones, in the air inlet on top of the radiator support to slow it down a tad and the idle smoothed right out and it runs strong. I like to do improvements even if it only slightly increases H.P./Torque or M.P.G. Because if you add up all the improvements they help each other out and the overall performance is worth it. My '96 is still the original motor and trans and I bet it's running better than when it left the factory 16 years ago but I'm always on top of things before they happen like hoses, vac lines, tune-up parts. It's sort of like therapy but cheaper than the couch! > -Kevin-The warm air input to a intake is there for a specific function and is controlled. You may be able to get away with that in Sunny California, but you need that input in areas that experience cold weather. It is controlled by the temperature of the air and is needed in cold areas for proper "cold start and run". Ford doesn't put stuff like that on the engine for grabs, they are into spending a little as possible to build a vehicle. If the temperature of the air entering the engine is proper, that input is closed off.
