i have a 1985 f150 4x4. i have a clunk in the front end. i found it is coming from drivers side when brakes are applied and i see the front axle where the radius arm connects at bottom moves when brakes applied. bolt is tight whats up could the hole where the bolt goes in be worn out. i was thinking of welding arm brackets to axle housing any thoughts thx jeff
