Chevy Disc brake conversion problems
69Bronco94
I am in the process of doing the chevy disc brake conversion on my 69 Bronco. I bench bled the master cylinder and got it ready out it on and started to bled all the brake lines. But i noticed that their is no pressure build up in the pedal went i pump it, i have to pump it a whole lot to get pressure then as soon as i let off the pedal its all gone and i have to pump it again. What I have noticed was that when i pumped the brakes, then let go that brake fluid squirts back up through the master cylinder, I'm pretty sure thats not normal, is it? I dont think it is and am wondering what i could have missed, or whats not holding the pressure in the brakes?
broncguy101
No that aint normal. Youll probly have to replace the master cylender.
69Bronco94
I have tried different ones, been through like 5 master cylinders now. Could it be anything else?
STLKIKN
Calgary Alberta
Some fluid return through the masters internal ports is normal, and is in fact necessary.
Besides the obvious (calipers, front lines, and m/ cyl) have you upgraded or changed any other components? ( ie: combination/ proportioning valve?)
Did you install a new power booster or adjustable pushrod?
Did you bleed the lines at the master as you were doing them up?
Have you got clean clear (new) fluid at the rear cylinders?
Do you have fluid flow at the new calipers?
Can you find any leaks at your new fittings?
Is your helper pumping the pedal slowly?
Has the master been run dry at any time during the bleeding process?
Are your rear brakes adjusted properly? (improper adjustment at the rear can make the bleeding process damn near impossible!)
If you still have problems after going through all the above, you will need to try a different bleeding process.... similar, but just a couple of new twists....
First you will need to try to "gravity bleed" each wheel individually. Crack the bleeder for one wheel, leave it open until you have some fluid flow through the ******.. repeat for each wheel, then move on to the next step. hint ; leave the lid loose on the master during this part of the process, it will allow gravity to take effect over the system.
Top up the master, and put the lid on ( it doesn't need to be clamped down right now, but it may make it a little less messy if it is...
The procedure is the same, but instead of pumping the pedal and then releasing pressure with the pedal held, you will be cracking the bleeder and then have your helper SLOWLY press the pedal to the floor. Tighten the bleeder, repeat until you have good flow each time the pedal is depressed. Then move on to the next wheel. Make sure to keep the m/ cyl topped up, it doesn't take much to run it dry this way!!
Do the wheels in this order... right rear, left rear, right front, left front....
good luck, let us know how it works out.
69Bronco94
I figured it out, well I didn't. I didn't have the calipers on the correct sides. the bleeder valves were not pointed up like they were suppose to.
jagscars
So how did the conversion go? did you get the parts list from this forum?I'm a new eb owner and am very interested in this conversion.
S_bolt19
Colorado
Bronco supply houses have them and you can do Google searches for "Chevy Disc Brake Conversion" and get some good answers. But There are a number of different components that can interchange with the front Dana 44. If you have the D30, I am not sure if it will work or not, I have never taken one apart.
Les Stimac
I'm also having problems with the same brake set-up
Everything is new Booster,mastercylinder ,lines (steel,rubber) porp.valve,front disc brake set-up everything.
I have no pedal I've tried gravity bleeding ,Pump bleeding using pedal and cracking the bleeders while pedal is down,tried a brake bleeder that pulls a vacum from bleeder *****. Still have a soft pedal.
I was just told there may be a reset button on the back of the Porp.valve is this true.
I'm trying to help someone out that has just bought a 69 Bronco that is in Great condition and all this brake stuff come with the truck I was just installing it .All this brake equip. was bought from The bronco graveyard and is new.
Thanks for the help
Les Stimac
69Bronco94
i got the spindles, backing plate off of the 75 K5. i brought chevy calipers and pads new, and new chevy brake lines, and all the bearings new. I think i have a 78 ford f250 master cylinder, and used the ford disc and hub. also bought new warn locking hubs. I got the whole parts list and procedures from a friend of mine, i think he got it off the internet somewhere. I have 35s and no booster and it works fine. Just make sure that the bleeder valve is pointed up on the caliper.
This conversion can also be done with the dana 30 ive been told but ur better off spending ur money on a dana 44
Les Stimac
i got the spindles, backing plate off of the 75 K5. i brought chevy calipers and pads new, and new chevy brake lines, and all the bearings new. I think i have a 78 ford f250 master cylinder, and used the ford disc and hub. also bought new warn locking hubs. I got the whole parts list and procedures from a friend of mine, i think he got it off the internet somewhere. I have 35s and no booster and it works fine. Just make sure that the bleeder valve is pointed up on the caliper. This conversion can also be done with the dana 30 ive been told but ur better off spending ur money on a dana 44
28346[/snapback]
bLEEDER ARE POINTED IN THE CORRECT DIRECTION ANY OTHER THOUGHTS I WILL BE WORKING ON THIS BRONCO IN THE MORNING.
LES STIMAC
STLKIKN
Calgary Alberta
may sound too simple to start with, if the truck has rear drums, make sure the rear brakes are adjusted properly, or you will have trouble getting them to bleed properly.
