check enigine light on and off
Krafty
Ontario Canada
Just yesterday I got my 89 efi 302 4x4 on the road. and last night I drove it 3.5 hours to Toronto. during that time my check engine light came on 3 separate times during the trip. nothing special about those times, just once in each of those 3 hours it would come on, and i would look down a little bit later and it was out. all my gauges work and everything was operating perfectly as far as the alternator, the temp, and the oil pressure.
any ideas? or just ignore it?
Boomballs
Wichita, KS
:huh: All of the fluid are kept up? Oils been changed within required time? Filters changed out? Mine did this once that my engine temp read normal but ending up being stuck. I was low on coolant but not low enough to overheat, itd just flash on/off once in a while.
50joe
Trenton NJ
If you wanna know for sure, your going to have to pull the codes to find out. If a scan tool isn't availible to you, i'm sure someone on here knows how to pull codes manually. Pretty sure Steve83 posted a way to do it.
Krafty
Krafty
Ontario Canada
I changed the oil 2 days ago and I topped up the coolant a while after the new rad support went in, I was making up for the air bubble that had come out.
my temp gauge does move, when it runs for a while either just sitting idling or in the city it reads just around half way in the normal range, and when its at highway speed it reads just below the N on normal.
and I can't check the codes cause I've never had it come on when I've been able to stop, the next time it does it and i have a couple pieces of wire kickin around, i'll be sure to stop and check it.
what do you mean by this? " Obvious answer of fuse shorting? ", what fuse? fuses don't short, they blow.
I'll double check all my fluid levels and stuff some time today.
ANT
I have only had my 88 5.0 for a week now. I have had no problems on short trips but a couple of trips that have been more then an hour I have had the same thing. Engine light goes on and off. I have not found any problems yet and everything runs fine when the light comes on. I will be watching this thread to see if I can get any ideas.
yo!
TSB 88-05-07 MIL Introduction
Publication Date: MARCH 2, 1988
FORD: 1988 ALL CAR LINES
LINCOLN-MERCURY: 1988 ALL CAR LINES
MERKUR: 1988 ALL CAR LINES
LIGHT TRUCK: 1988 ALL LIGHT TRUCK LINES
ISSUE: The Malfunction Indicator Light (MIL) is a new feature that has been added to 1988 vehicles. Vehicle applications follow. The MIL's (Check Engine) is active when the engine system requires service. An explanation of how and when the Malfunction Indicator Light (MIL) operates may need to be explained to some vehicle owners.
ACTION: Use the following service information to explain the operation of the Malfunction Indicator Light (MIL) to resolve customer concerns.
NOTE: IT IS NOT NECESSARY TO IMMEDIATELY TURN OFF THE ENGINE OR HAVE THE VEHICLE TOWED WHEN THE "CHECK ENGINE" (MIL) LIGHT COMES ON.
Vehicles Equipped with EEC IV
The CHECK ENGINE light will come on while engine is operating in Failure Mode Effects Management (FMEM) or Hardware Limited Operation Strategy (HLOS) modes. The light will stay on as long as the fault causing it is present.
In FMEM mode, the computer is receiving a sensor signal that is outside the limits set by the calibration strategy. In this mode, the computer uses an alternate strategy to maintain reasonable vehicle operation in spite of the fault. The following chart lists the system faults which will turn on the CHECK ENGINE light in this mode. The error code associated with this system fault is stored in Keep Alive Memory (KAM). If the fault is no longer present, the light will turn off and vehicle will return to normal vehicle strategy. The error code stored when the light was on was not erased. This code is one of the continuous error codes and can be accessed by running the KOEO self-test.
HLOS mode is used when the system fault(s) is too extreme for the FMEM mode to handle. In HLOS mode, all software operations have stopped and the computer is running on hardware control only. The default strategy for this mode has a minimal calibration just to allow the vehicle to operate until it can be serviced.
NOTE: IN HLOS MODE YOU WILL NOT GET ERROR CODES.
The MIL light is turned on as a bulb check when the ignition key is first turned "ON". The EEC IV computer turns off the bulb as soon as it receives the PIP (crank) signal. If the light stays on during cranking, the computer is not receiving the PIP signal.
To service a MIL concern, use the 1988 Engine/Emission Diagnosis Shop Manual, Volume H, Section 16. If the vehicle has no drive problems, the MIL is on, and no codes are found in memory, follow diagnostics by symptom in the 1988 Engine/Emission Diagnosis Shop Manual, Volume H, Sections 17 or 18.
Non-EEC IV Vehicles
The Malfunction Indicator Light (MIL) alerts the customer that 60,000 mile emission system maintained is required. To service a MIL concern on a non-EEC IV vehicle, refer to the 1988 Engine/Emission Diagnostic Shop Manual, Volume H, Section 13.
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: INFORMATION ONLY
by Ford via Steve83
