check engine light
samsbronco
Emory Texas
Hi guys i have a problem with my bronco it runns fine almost all the time except wen you are driving and you giv it a little gas the check engine light comes on for a few seconds and might blink a time or two and then goes off i just put on a new set of vaccume lines so i am confused it does not do any thing wierd it dose not miss,spit or sputter s i am at a loss as to why it does this the reason this has been bugging me is i have to get it inspected in december and have checked everthing i can think of
thanks for youre help Sam
93 bronco eb all stock 212K
Pull the codes. I'm thinking that someting is responding a little slow to changes the computer is making to the fuel mixture and causing the O2 sensor to momentarily sense a rich condition.
S
samsbronco
Emory Texas
I took it over to my buddies shop and the o2 sensor the plug was kind of crappy don't think it has been replaced in a long time since I put a new one on it has run fine and no light thanks guys for you're help
I do have one question about my other bronco I have put a timing chain and heads,water pump distributor and street fierce controller what is the best timing setting to run it at ? or should I stay with the factory setting?
It has a 351 with shorty headers, new heads ported and polished,Ford racing gaskets though ought the motor no air system cold air intake and no tuning yet .
It is waiting for a alternator (had it in the back of my Eddie and someone need it more than I did apparently they busted out the back window to get it and some tools f him) thanks,Sam
If it is an EFI engine, I'd set it per the factory specification. the computer will just attempt to move it back to that any way. If it is a Carbed engine 12 to 13 BTDC works nice.
digs
