Check Engine Light (I've got codes!)
KJEfting
Ogden, Utah
Pulled the codes today and got six different ones. I'm looking for input on possible fixes for these. Codes are listed below in the order in which they were displayed. Thanks in advance for the help.
172 : System indicates lean
179 : Fuel system at lean adaptive limit at part throttle, system rich
332 : Insufficient EGR flow detected
171 : Fuel system at adaptive limits
617 : 1-2 shift error
628 : Excessive converter clutch slippage
I replace the EGR valve two weeks ago, so I think that may just be a stored code from earlier. Should I yank the battery and reset the system to get updated codes? The tranny does shift a little bit hard from 1st to 2nd, but it's not too bad yet. Is this possibly a sensor of sort, or an internal transmission issue? I've got a 351 that doesn't have as much power as it should. I've checked my compression and all eight cylinders are good. The engine had a fresh tune-up about 8,000 miles ago. I suspected that I had an issue in the fuel system and the codes seem to confirm that. Any ideas fellas? I'm pretty new to the Bronco scene, but I'm mechanically inclined and willing to tackle just about any job. I'm just trying to find a good starting point. Thanks a ton.
-Ken
yo!
here are some possibilities for each;
Vacuum Leaks
PCV system & Hose stuck or blocked
EGR sys
Leaking gasket
Stuck EGR valve
Leaking diaphragm or EVR
Exhaust leaks before or near the HO2Ss
Leaking fuel pressure regulator
Low fuel pressure or running out of fuel -Leaking or bad fuel injector(s) or fuel filter; when was it last replaced?Vapor recovery sys
Excessive fuel pressure
Air leaks after MAF
also aee my site for the TSB
http://home.comcast.net/~miesk5/technical_...d%20for%2090-93
Same as 171
Right or Rear HO2S
Poor continuity in EVP harness or connectors.
Open or short in EVP sensor or harness.
Damaged EVP sensor.
Obstructed or cracked vacuum hose
Detonation and/or Malfunction Indicator Lamp (MIL) Illumination w/ DTCs 332, P1407, and/or P1408, TSB 96-23 Caused by buildup in the Exhaust Gas Re-circulation (EGR) groove of the intake manifold (throttle body base. by Ford via autorepair.about.com
http://autorepair.about.com/library/faqs/bl267c.htm
harness wiring - check all connectors
check power to the solenoid connector at the tranny
see Fordace's info ans TSB there
http://www.lincolnsonline.com/forum/showthread.php?p=498844
THAT IS IT FOR NOW; HAVE TO ROLL
GL!
-Ken
Motormouth2025
