74EBinIDAHO
- Joined
- Apr 14, 2004
- Messages
- 8
- Reaction score
- 0
I have just finished replacing my whole wire harness with a centech harness from JBGY. Everything worked first time except the blinkers. When I select left turn, my rear left blinker flashes, like normal, but both of my front blinkers flash. If I select right turn, the same thing happens, I get the rear right signal as I should, but both front blinkers flash. I have replaced the column harness(turn signal and horn harness) and double checked my grounds at both front blinker housings. All running lights work correct as do the stop lights. Any ideas. Thanks :wacko:
