cb radio
bigbronc2632
im planning on putting a cb radio. i was wondering if any of you have any suggestions i was looking at the cobra brands and they looked pretty good but i was wondering if yall knew of any other good ones i want something at a low cost because i am on a budget but it needs to last me a while i also want the weather channel on it but thats the only major requirement. i was also wondering wat yall thought about a 8 ft whip antenna mounted on the bumber and pulled back to clip on the side of the truck
lawman212
Yep a Cobra is a good CB Radio I have one on Lay-Away for $60.00 at Wal-Mart. I have a McKinley right now that don't work worth a crap about twenty years old!! With CB Radio's you get what you pay for. You can pick up a Midland CB for about $30.00 on the cheap side. Some of the cheap Midland's are small and thin and can fit easy into yor truck. I had a Midland installed in the dash of my old 1987 Toyota truck that worked pretty good. It all depends on what you want and what you want to spend. My wife would have killed me iF I had paid for that Cobra out right. IF you have a Wal-Mart or K-mart that sells CB Radio's put one on Lay-Away. Not All stores sell them. Out of four Super Wal-Mart Stores here in and round Daytona Beach, Fla. only one sold CB Radios. Good Luck in your hunt.
Also my Cobra thats on Lay-Way has the Weather Alert button for the weather Bands and a built in speaker. Not all CB Radios have built in speakers. The Cheap Midland CB's don't have speakers and only have a plug for an EXT. speaker on the back.
mgd2rw
Cobra's are good and unidens are good too. I would buy one that has a rotary channel selector, or a second power wire that is connected to constant battery. That way it will retain the channel you had on before you shut the truck off. Hope that helps
bigbronc2632
bigbronc2632
thanks yall have been a big help i was lookin at a cobra i can only spend about 100 or less on it. the whole walmart thing is a good idea i live up in tampa myself so i guess i can go check those i went to radioshack but all they have is a radioshack cb and i dont know how good that would be and i did find a 6' whip that cost almost as much as the cbs but hey u do get what you pay for im also gonna check out some other store around here that my freind told me specializes in this stuff i just think itll probably be too expensive just because its a specialty store
lawman212
I was born a raised in Tampa went to Plant High, a good place to get CB Equipment is at the truck stops. Try the truck stop on 92 if it's still there, I got some CB Equipment at the one South of Wildwood off of I-95 for my McKinley just the Ant. Mirror Mount and cable but paid 1/2 of what it was at the Radio Shack which isn't wroth crap anymore for parts!! :angry: You use to be able to buy any kind of radio/CB part there but not anymore.
lawman212
Bandit
BANDIT
Afton,Wyoming
Bigbronc,the thing about C-B radios is this...if want to start out with a real good one with legal max power from the get go it will be alot more than 100 bucks.If you going to modify them you have got to watch out some of them you cant modify.The Cobra classic 29 is decent its fairly low price and are highly tunable.I drove big truck for a few years and have a couple of cobras.If you go to any truck stop with someone with a CB,thertes almost allways a truckdriver broke and selling cheap.If youre going to modify one though,its usually illegal all of mine put out illegal power but if you want distance and clarity thats the reality of it . <)
k1w1t1m
Bentonville AR
I have never seen a NEW CB that doesn't transmit less than the legal maximum power.
Ihave had a RS CB and found it pretty good. It had the Weather Channels on it as well. Some RS's also have the 102" stainless whips which I have mounted on my spare tire rack. I have found the 102" whip to be a PITA as it hits everything. I now have a 4' base loaded antenna. I can't tell the difference between the two as far as Xmit and Rx.
HTH
Tim
hms79
Marion, IL
Here are some helpful hints:
1. Cobra and Uniden are identical
2. Anything Midland and Maxon is junk
3. your top models are Galaxy, Connex, and Texas Ranger. However, you would be looking at spending at least $150 on any of those three brands, minimum.
4. Stay away from old 23 channel Radios
Since you are on a budget, Cobra 25LTD, 29LTD, or Uniden PC68 or PC78 are the best bet. Properly tuned and used, these radios will talk with the best any day of the week. Try finding a CB shop and see about used CB's. I have a Cobra 29 GTL that is over 20 years old and 40 channel that has never failed me. Cb's are great fun, enjoy! :)>-
bigbronc2632
bigbronc2632
thanks yall yeah i have been thinking about that 102" whip so im not sure about it. but i think im gonna get a cobra 18 WX ST II Mobile CB its in my price range and it seems pretty good any one have or know anything about it
wrachet
Kansas City Area
Best way to find out what a good CB Radio is...go to truck stop...ask the truckers! They'll tell you...
Colleen
firelt90bronco
Ask me about my job
northeast
I got a Kraco cb with a whip and it looks good. I got the radio from my grandfather and it has a lot of value to me.
scrubtopdoc
