opy
I have no cat on the old beast (off road us only?). The truck runs rich, I am assuming because the cat is gone. The O2 sensor was put back in the new pipe where it would have been in the cat. Any suggestions to correct the mixture?
i wanted my truck to sound rich and loud too i cut off the cats and there was an 02 senser at first the engine light stayed on but when i had pipes welded it cuttoff i assume that the 02 sensor only checks for back pressure but then again im not a mechanic
I'm not a Bronco expert & i couldn't tell you without actually looking, what you may have & where the location is...I have no cat on the old beast (off road us only?). The truck runs rich, I am assuming because the cat is gone. The O2 sensor was put back in the new pipe where it would have been in the cat. Any suggestions to correct the mixture?
The o2 sensor is still on the truck i just dont have any catsBasically the O2 sensor measures the exhaust for combustibles & sends a signal back to the ECU which adjusts for the excess fuel or air, depending on what the O2 reads... there are different types, of O2 senors as well, but they all basically do the same...
If the vehicle is designed with an O2 sensor, it is best that you always have one, unless you redesign fuel/intake. Or your vehicle will always run either to lean or rich, which will cause internal engine problems...
