lukeyboy60
Just got a new carb and it has elec. choke. Previous carb didn't. What do I need to do to connect it up?
The field wire is only good for some Ford Carbs because it is normally only 7 volts which the Ford carb chokes were designed for. You can tap it off the Red with Light Green stripe wire that goes to the coil (+).The electric choke just needs 12 volts when the key is in the run position so you either have to find a power point in the fuse box that is on when the key is in the run position or you can hook it to the I believe the field wire from the alternator . /emoticons/[email protected] 2x" width="20" height="20" />
The electric choke is a bimetal spring when you put 12 volts to it the spring gets hot and it unwinds . If you ever have a bad one to take apart as I have there is another bimetal contact system under the cover of the + side spade connector when this gets to a certain temp it breaks contact interupting power to the main coil spring in the choke housing . When you set the choke you are winding the spring up as you turn the housing to close the choke when the spring gets hot it unwinds letting the choke open . The other system under the spade acts as a voltage regulator in sorts . If you want to see this work so you know Im not talking out my **** take the choke cover off and look at the inside you will see the spring now clip a battery charger on it and turn it on then watch the spring it will start to unwind thats how it works /emoticons/[email protected] 2x" width="20" height="20" />
