79fordblake
I am having trouble with the stock 2barrel carb on my stock 400 in my 79 Bronco. I had a problem with trash stopping up my lines, filter, and carb. So I installed a new tank, new electric fuel pump, new rubber line and cleaned out all the hard line. Now I have a good fuel supply goin to the carb and fuel filter is crystal clear, but I am still having running problems.
Sometimes while driving or just idling it will start to idel really low and miss, but no smoke. Sometimes it will clear out after awhile and be fine again. While it is idling real low and missing if I close the choke manually it will run good if I let it open up it will miss and idle low.
What is the best way to take one of these carbs apart and clean it? Or is it just bad? It is a remanufactured carb about a year old.
