crazzyace90
- Joined
- Mar 9, 2010
- Messages
- 4
- Reaction score
- 0
i had a coolant leak and i took it into the same guy (trans shop. only shop i trust) who put my gears and locker in.
it looked like it was coming from the timing cover but i wasnt sure.
long story short, it was, and hes charging me about 700 for:
new water pump
timing cover
timing set & chain
coolant flush
oil change(coolant will get in oil from taking timing cover off)
all gaskets
he said alot of labor. said parts are only like 200-250.
but ive always wanted a new cam (nothing major expecially with speed density)and i know the cam is right there when you have the timing apart.
for the cam, he then quoted me 1300(other stuff above included) and thats with ME bringing in all the cam parts. i want the E303 ford racing cam and im pretty sure id need new hyd roller lifters and thats another like 250.
so with that said, is the 1300 (1550 est. with cam parts) a so-so price for a cam install and the coolant stuff?
i figured it would only take a few extra labor hours because i have had the top end apart myself before and all you would really need to take apart is the plenum and the valve covers. the rockers come right off and you could just use those magnetic (i forget the name of the tool) to hold the lifters up and make it possible to swap the cam WITHOUT taking the intake manifold off. he said hes never done a cam and not changed the lifters so the intake would have the come off as well as all the accessories on front and obviously distibutor with the intake off.
basically down to the block and heads. he said another 11 hours of labor?
im 99% for just telling him to take the 700 and fix the coolant leak.
thanks for anyone who takes the time to read this.
i used to come on here but forgot my info so i set up a new account.
new water pump
timing cover
timing set & chain
coolant flush
all gaskets
