The prop shaft nose ( the bit that fits into the C6) is painted. Does anyone know the correct outside diameter for the prop shaft nose ? I am getting vibration on the prop shaft but I'm not sure if the bearing is missing in the extension housing of the c6 or if the prop shaft nose is the wrong size. Thanks Jon.
