I have a '77 Bronco with a C4 Trans. I recently had it rebuilt and I am having a leak around the shift shaft. I have heard of a o-ring and possibly a lip seal that could cause the leak. If this is the cause...does anyone know if I can change the seal or seals in the truck and do I have to remove the pan and valve body to do so? Also...where can I get these parts? I would appreciate any info you may have on the subject.
