C-4 Kickdown
lcac24
Oceanside, CA
I need some info on the C-4 kickdown. I have 1970 with a 93' 5.0/C-4 and I am not sure how it is supposed to work. Any help would be appreciated!!!
STLKIKN
Calgary Alberta
Assuming that you are running fuel injection on the 5.0,
You will need to find a cable operated kickdown conversion.
The factory kickdown rod won't work with the FI.
I have had great success using Lokar products for this type of conversion.
Check with your local speed shop, they should be able to help you out.
I believe the part number you need will be Lokar KD20C4HT
79' Buckin Bronco
