Bull Bar for 1996 Bronco
McJix
Hello,
I am interested in getting a bull bar for my '96 Bronco. There's one problem though -- I can't find one.
I have had some luck with finding one for a 1996 F150 under the Westin brand. My question is: Will a bolt-on frame bull bar that fits a 1996 F150 fit a 1996 Bronco? If I am correct, I believe that they use the same frame, albeit the bronco's is cut back in the rear.
Or better yet, does anyone here know a place that still manufactures bull bars specificaly for the 92-96 Broncos?
Krafty
Ontario Canada
for the bronco's and f150's pretty much everything doors forward are exactly the same, including bumpers, mounting points for bull bars, ect.
Elmo
Forsyth Georgia
On the F series trucks isnt there a difference between the frame width between the 4x2 and the 4x4. That I believe would be the only problem, not that you would be looking at one for a 4x2 but info worth noting maybe.
Elmo
Forsyth Georgia
Krafty
Ontario Canada
elmo just for future reference
the frames of the two vehicles are identical, the only difference between a 4x2 and 4x4 are as follows, -Transmission output shaft- Transfer case (vs no case)- front axle - and spindles, coil spring height.
they do this to be able to have as many different combinations of truck on the same few frames.
