Brush guard
SASSQASH
I am interested to know if a brushguard from a 2000 F150 will fit a 1996 bronco. I understand that anything can fit with a little ingenuity and welding, however, im curious if it is a direct fit may just some spacers or something. thanks
I haven't heard of this .. yet.
My 96 stock front bumper is approx 77" wide
96 Body width is 79.1"
The Setina Push Bar is approx 33" wide and is bolted to bumper
Look @ this and try to get more dimensions; I am having Comcast issues and alreay have lost one reply when CC shut down
2000 Body Builders Layout Book
https://www.fleet.ford.com/truckbbas/non-html/2000/134_135.PDF
look @
W702 FRONT BUMPER WIDTH
4x2 1880mm (74")
4x4 1892mm [74.5"]
To help; look @ this frame dimension diagram a 92; 92-96 & F150 similar92broncoframedimensionsinmm.jpg
780mm (30.7" from centrline to
SASSQASH
SASSQASH
My assumption is that it will not work based upon the body changes from 97&up. there was a brush guard available for sale for a good price, hence the question. Figured someone on this site has attempted this due to the amount of modifications I've been reading about. Wife will freak if I get something, again, that doesn't fit and see's me doing what she calls "wierd stuff" to make it work. But, it's always worth needing new tools!
Krafty
Ontario Canada
if you've got a welder and a grinder you can look at just fabing up something from scratch I used this warn product as a template and started making one. I've got my bumper brackets finished and painted I just need to cut out a template for my two uprights but work on my other projects has been slowing down the bush bar.
bushbar.pdf
Here's what you do.....get the part, do what your wife calls the "weird stuff" to it. When she freaks, tell her it's because you wanted to save money so she could buy shoes. Then give her a 20 and she will leave you alone...........................till next time.
GOOD LUCK!
Sandoval_broncosauria
