Bronco won't start
351 1986
So, I have 1986 351' windsor. When i try to crank the truck a loud clicking noise comes from the right fender by battery. I replaced the cylonoid starter, because it sounded like the noise was coming from it. But, I still got same problem. I would love some feed back ......hate to see my **** truck sit
yo 351 1986,
WELCOME!
Is the part you replaced on passenger side fender liner? If so, it is usually described by Ford as a starter relay; make sure it is attached to fender liner tightly; no rust or grome between it and liner because this is the ground path for the coil inside it.
Is battery charged? Do you have a multimeter?
Clean your battery terminals and check ground cable from battery.
& see this Starter Relay Ground Wire Addition & Location Video in an 86
Source: by JKossarides ("The Bronco", Jean) at http://www.supermotors.net/registry/media/782810
Starter Relay Wiring Diagram in an 86
Source: by Xris at SuperMotors.net
Ck for voltage along the path
eholt80
