Bronco Top Bolts
SDBronco91
Tennessee
Hey guys I was checking on replacing the bolts/clips to my 95 Bronco and looked on the Bronco Graveyard to get them. Although they have the clips for the 92-96, they don't have the bolts for the 92-96. They do, however, have them for up till the 91 models. From what I've read they started using a security bolt rather than hex bolts at some point, but that was the only difference i could find. Will i be alright if I buy the top and side bolts that fit the 91 models?
yo SD;
Security Torx bolts were first used in 92
Look @ this
Removal w/Tool List, & Security Torx® bolt replacement w/Metric sized bolts in 92-96;
(5 8x70mm 1.5 Pitch Metric Bolts & 12 8x45mm 1.5 Pitch Metric Bolts) Source: by Froggmann (Ken P) at http://www.froggmann.com/Bronco/Tech/Topremoval.htm
Also;
Trim Panel Retainer (Pushpin, Nylon), , Interior, Plastic in 92-96 (Xmas Tree, part # N19374) (New URL as of JUN 2010) Bottom Head Diameter: 19/32" - Stem Diameter: 9/32" - Stem Length: 27/32" Source: by northlandfasteners.com
if Image does Not appear; see it at the Link above.
Trim Panel Retainers (Pushpin, Nylon), Interior, Plastic, pics & Ford part number N808658-SSD (Mocha Tan) in a 95 Source: by fearxfour (fourxfour95
Body Side and Roof Rear Garnish Mouldings, Bronco, Parts Break-Out Diagram w/nomenclature in a 96 by Ford via thedieselstop.comGL!
http://www.thedieselstop.com/faq/9497faq/maint/stj/images/r8389c.gif
Item Part Number Description
1 517C04 Roof Trim Rear Moulding
2 29004 Quarter Window Garnish Lower Front Moulding
3 N8071545-SW Pushpin (6 Req'd Each Side)
4 N807372-S Pushpin, Nylon (2 Req'd Each Side)
5 29010 Quarter Rear Window Garnish Rear Moulding
6 29126 Body Side Window Garnish Moulding Front Bracket
7 N800486-S9 Bolt and Washer
8 N801157-S58 ***** and Washer (2 Req'd Each Side, 1 Req'd Center)
9 518B34 Roof Trim Rear Moulding Joint Cover
10 29070 Body Side Window Garnish Moulding Bracket
btw, I have more trim info Links in my broncolinks.com site @ http://www.broncolinks.com/index.php?index=476
The threads are the same, the only difference is the head style. They put the security bolts on when the added the 3rd brake light and rear seat shoulder belts to discourage removing the top. As I understand it, in most states it is not legal to drive a vehicle that has a 3rd brake light from the factory without it or have passengers in the rear seat without shoulder belts. If you wanted to keep legal with a 92 and no top you would need to do something like add a roll bar that could have both attached to it.
digs
