bronco tailgate
Yo Tim,
Welcome and congrats on acquiring the best year Big Bronco EVER !
Swapping (t'gate differences between the years); "...Amazingly throughout the number of body style changes from 78 through 96, the tailgate remained nearly the same. You can swap tailgates between all of these years taking note of the following: I've broken down the 3 major changes into their respective years.
78-79 Type A;
80-82 Type B;
83-96 Type C;
If your swapping within the same type it's just a direct swap.
If swapping A & B you have to switch the glass and glass support brackets; If swapping B & C you have to switch latches and striker plates; If swapping A & C you have to switch the glass, glass support brackets, latches & striker plates..."
Source: by Mike M (MRM) at his old medicine.wisc.edu site via web.archive.net
Tailgate Internals Swap by Dustin S @ http://ylobronc.users.superford.org/tailgate.html
Dustin includes personal safety issues and work arounds.
Inspect weatherstrip for grime, lack of lubrication. Clean ws with water/Dawn mixture, then clean water.
Ford recommends, "Use Silicone Lubricant C0AZ-19553-AA (jelly) or D7AZ-19553-AA (spray) or equivalent meeting Ford specification ESR-M13P4-A on the door and window weatherstrips whenever necessary. Silicone lubricant helps avoid weatherstrip squeaks and retards excess weatherstrip wear from chafing between the glass and the weatherstrip. It also helps to retain glass alignment by reducing friction between the glass frame and the rubber weatherstrip.
miesk5 note, test the silicone on a regular styrofoam cup first; if the cup gets funky or melts, then the can or tube contans oil, a regular occurrence now, esp if from China.
More tg **** info:
Use Multi-Purpose Grease or equivalent meeting Ford specifications ESR-M1C159-A and ESB-M1C106-B to lubricate door and tailgate hinges. Apply an even coat to all hinge pivot points as outlined in the maintenance schedules or when a binding or squeaking condition occurs..." I bought a can of Motorcraft
Multi-Purpose Grease @ Advance Auto
I use DuPont™ Non-Stick Dry Film Lubricant with Teflon™ on the flocked edges that hug the glass. See attached pic
"Take off the TG access cover and spray Tri-Flow in the tracks on either side so the regulator toggles slide up and down easy" by our late friend here JKossarides.
"The best grease for the slides & tracks is PTFE". by Steve
Is window regulator rusted badly? If so, clean & **** it with multi purpose grease.
Are Glass rollers ok? They may need to be replaced.
Ensure that the motor is mounted properly to the back of the regulator.
Tailgate could be mis-aligned. Inspect gaps between each side of the tailgate and the quarter panels. If the tailgate is too high or low, the latch jaws will cut into the striker bushings, so inspect them.
Tailgate Motor Rebuild wirh Dorman Roller kit and Regulator Removal with pics in a 92 @ https://www.fullsizebronco.com/threads/fixing-the-rear-window-motor.179496/
Tailgate Glass Roller Replacement @ https://www.fullsizebronco.com/threads/replacing-the-swivel-slide-and-rear-window.160291/
"... View attachment 21743
All '80-96 t/g wiring runs from the dash switch (F2TZ-14529-A Motorcraft SW7071 ~$25~65) out the firewall along the frame to the rear bumper up to the L taillight and into the t/g. '80-86 have a large round 3-wire connector in the LHR taillight well; those with rear defrost also have a 1-wire connector. All years with rear defrost have a ground ring screwed to the body in the taillight well. I think '87-91 have the large round connector in front of the taillight AND a smaller round 4-wire connector inside the frame at the LHR body mount. '92-96 only have the frame connector.
Normal operation is as follows:
RAISE from the dash switch:
Power flows thru fuse 14 thru the LB/BK wire thru the IP switch UP contacts thru the P/LG wire thru the key switch UP contacts thru the Y/R wire to the motor brushes, commutator, & windings; then it grounds thru the motor's internal CB, out thru the R/Y wire thru the latch switch thru the T/Bk wire thru the key switch DOWN contacts thru the Pk/LB wire thru the IP switch DOWN contacts to the Bk wire to the ground in the kick panel (or dash on older Broncos).
LOWER from the dash switch:
Power flows thru fuse 14 thru the LB/BK wire thru the IP switch DOWN contacts thru the Pk/LB wire thru the key switch DOWN contacts thru the T/Bk wire thru the latch switch thru the R/Y wire thru the motor's internal CB to the motor brushes, commutator, & windings; then it grounds out thru the Y/R wire thru the key switch UP contacts thru the P/LG wire thru the IP switch UP contacts to the Bk wire to the ground in the kick panel (or dash on older Broncos).
RAISE from the key switch:
Power flows thru fuse 12 thru the BK/Wh wire thru the key switch thru the UP contacts thru the Y/R wire to the motor brushes, commutator, & windings; then it grounds thru the motor's internal CB out thru the R/Y wire thru the latch switch thru the T/Bk wire thru the key switch DOWN contacts thru the Pk/LB wire thru the IP switch DOWN contacts to the Bk wire to the ground in the kick panel (or dash on older Broncos).
LOWER from the key switch:
Power flows thru fuse 12 thru the BK/Wh wire thru the key switch DOWN contacts thru the T/Bk wire thru the latch switch thru the R/Y wire thru the motor's internal CB to the motor brushes, commutator, & windings; then it grounds out thru the Y/R wire thru the key switch UP contacts thru the P/LG wire thru the IP switch UP contacts to the Bk wire to the ground in the kick panel (or dash on older Broncos).
Note that in ALL cases, EVERY switch is used, and the circuit ALWAYS grounds at the same point." By Steve
ASAP, find out if speed control recall work, if equipped was completed @ Recalls Look-up by VIN (Vehicle Identification Number); or @ Welcome to Ford Owner | Official Ford Owner Site; or ... have VIN ready. While there, see most Ford dealer maintenance/repairs done @ any dealership nation-wide.
To confirm current status, use this guide by jowens1126 @ 93 & 94-96 Cruise Control Recalls Repair
Note that the 93 recall is different than the 94-96 recall.
See Baba Looey's Favorite FSB Links (lots and lots of tech links)
Here's the 1996 Bronco/F-Series Workshop Manual partial
96 Bronco Owner's Guide, Maintenance Schedules & Parts and Accessories by Ford @ Owner Manuals | fleet.ford.com
96 Bronco Dealer Brochure @ 1996 Ford Bronco Technical Info pictures, videos, and sounds | SuperMotors.net ... scroll down
96 Bronco Quick Tips Brochure Excerpts & some Eddie Bauer options @ 1983 Ford Bronco 96 EB Bronco Brochures pictures, videos, and sounds | SuperMotors.net
Register to see most Ford dealer maintenance/repairs done @ any dealership nation-wide @ Welcome to Ford Owner | Official Ford Owner Site
Virgil3rd
