bronco rims on f150
mudydog
will the rims off a '90 bronco fit on a '77 f150
the rims ar 5 on 5.5 but will the rims fit over the hub if its a 4x4 w/manual locking hubs.
im selling them to a guy with the 150 so i dont know much about the truck.
Probably, compare the hub diameter to the hole in the rim. The hole in my rims is just a little larger then the hub size and as long as both are lug centric there should be no problem. I believe the set back is the same for both years.
Are they going on a 77 F150 or F250? You asked if they will go on a F150 but selling them to a guy with a F250? :huh:
M
mudydog
woops sorry about that, there going on a 150
